Hi guys !
Can I, in my basic msi project , set the order of installation of two selected subfutures of the same feature, ie, I have this design of my setup :
"SQL"
|---->"Engine"
|---->"SQL Management"
"Application"
|---->"Client"
|---->"Server"
If I select, the subfeatures "Engine" of the features "SQL", the subfeatures "SQL Management" of the features "SQL", the subfeatures "Server" of the features "Application":
I want to be installed:
in first time, the subfeatures "Engine" of the features "SQL"
(here, I will launch a CA that will install in silent mode SQL server 2008, and then set a property with the name of the SQL instance newly installed )
in second time, the subfeatures "SQL Management" of the features "SQL"
in third time, the subfeatures "Server" of the features "Application"
(here, i want to trigger a CA with the SQL login and SQL browser dialogs and then proceed to normal installation of the subfeatures)
have suggestions for me ???
Can I set the installation order of the features
AngeloF
, Feb 15 2011 12:28
Posted 15 February 2011 - 16:25
Windows Installer doesn't actually install Features, it installs Components. As I understand it, unfortunately, you cannot reliably control the order in which it installs Components. I don't really have any suggestions for you, though. Sorry.
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 15 February 2011 - 16:54
I associated with a component for each subfeature.
here, the new question is :
Can I set the order of installation of a component before another??
There are no properties to prioritize the installation of a component?
Can I insert a custom Action between the installations of components??How do it ?
Edited by AngeloF, 15 February 2011 - 16:56.
Posted 16 February 2011 - 22:15
