Hello,
How can I remove a non-uninstallable msp patch without the application uninstalling?
Thank you for you help
Roman
Non-uninstallable msp patch
romasha
, Dec 02 2010 08:52
Posted 03 December 2010 - 10:25
Holy cow...
Re-read your question. Got the answer now?
Posted 03 December 2010 - 12:59
You could create an "anti-patch" that installs the previous version of the file (you would however have to increment the version number of the file).
Posted 03 December 2010 - 13:05
Given the question, do you think the OP has the necessary skills to do that?
Posted 03 December 2010 - 13:37
Thanks for the answer.
I cannot create an "anti-patch" because 2 error was done:
1. The msp patch was created as non-uninstallable.
2. The InstallShield project which was used fro this patch creating was lost.
The msp patch is very simple. It replaces some files only.
I found the solution:
I found in the registry ("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products") the product and then set the "Uninstallable" value to the "1" (instead of the "0") for this patch.
Roman
Roman
Posted 03 December 2010 - 13:42
Congratulations. You now know how to make your target machines unstable by allowing uninstallable patches to be uninstalled.
Do you understand why a patch would be made uninstallable? Do you know what a patch is?
