Hi everybody,
I have created an Installer (MSI type, developed by Visual Studio Setup Project) that has to check OS version is Windows XP 32-bit (English), but I don't know how to check Windows XP-32 bit English .vs Windows XP 64-bit English or Windows XP 32-bit French. Can anyone help me?
Thanks for helping.
How to check OS version by Setup Project
accessdenied
, Nov 30 2010 08:54
6 replies to this topic
Posted 30 November 2010 - 09:41
You should be able to find something of use in the WMI Win32_OperatingSystem class properties
Edited by VBScab, 30 November 2010 - 09:41.
Posted 30 November 2010 - 10:09
Thanks for your help. But how to use information in Win32_OperatingSystem without coding?
Posted 30 November 2010 - 15:23
You could use the pre-defined properties in Windows Installer, such as VersionNT vs. VersionNT64 and SystemLanguageID.
Posted 01 December 2010 - 04:25
| QUOTE (Stefan Krueger @ 2010-11-30 15:23) |
| You could use the pre-defined properties in Windows Installer, such as VersionNT vs. VersionNT64 and SystemLanguageID. |
Thanks for your help. I have solved this issue. But I have another issue when I try to install package (a setup.exe file plus a *.msi file) from a location on a network. It showed message "This installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this is a valid Windows Installer package. ", but when I install package from local computer, it's fine. How can I solve this issue?
Posted 01 December 2010 - 13:00
Make sure that the network share is available for the LocalSystem account, too.
Posted 03 December 2010 - 03:17
| QUOTE (Stefan Krueger @ 2010-12-01 13:00) |
| Make sure that the network share is available for the LocalSystem account, too. |
OK, thank you. When I run *.msi file on a shared folder that has Full control, it is OK, but when I run that file on a shared folder that has Modify control, it has the same issue.
