I am getting a failure on one machine when I run LaunchAppEx. CreateProcessA is returning a failure. Is there any documentation I can get on CreateProcessA? This failure occurs on one particular machine and only if the user chooses the default installation directory. The path names are of reasonable length. Permissions on the directories involved seem to be ok as I can run the same command lime manually. Does anybody have a clue about what may break CreateProcessA()? Thanks for any info.
LaunchAppEx problem from CreateprocessA
pwhorisk
, Mar 20 2002 18:04
Posted 20 March 2002 - 22:47
CreateProcessA is the ANSI version of the CreateProcess Windows API. It is documented in MSDN. Please let me know what you find out.
