I was wondering what would be the best solution to tackle an issue I have.
I'm using WPS 4.62 on a Windows 2000 machine and I want my package to install in the appropriate SYSTEM32 folder for the Windows 2000 and Windows XP client machines I will be installing it to. My issue is that in Windows 2000, the windir folder is C:\WINNT and in XP, it's C:\WINDOWS.
Should I create separate components for the files that will be saved to those locations to have a condition check of whether the client machine is windows 2000 or windows xp?
Alternatively, is there some way I can make use of the "windir" environment variable to get around this? Perhaps through the use of some property or over-riding the SystemFolder and WindowsFolder path variables???
Basically, how do I get the package to intelligently work out which folder it needs to install files to for windows 2000 and windows xp machines?
WINNT and WINDOWS
skj
, Apr 14 2005 06:54
Posted 14 April 2005 - 09:08
Use the predefined WindowsFolder or SystemFolder property respectively.
