Extracting Self-Extracting Installer Files
simontrain
, Jul 07 2005 10:01
6 replies to this topic
Posted 07 July 2005 - 10:01
We're trying to find a way of extracting the files from self-extracting executable installers (Installshield).
We want to be able to extract the MSI file and all supporting CAB files etc. from an Installshield EXE installer.
We want to build this functionality into a tool, and the command line approach seems to be unreliable as different EXE installer have their own command line switches.
Any ideas?
Thanks, Simon
Any ideas?
Thanks, Simon
Posted 07 July 2005 - 10:21
You basically have two options:
A) find out which command line parameters the exe supports. InstallShield only has a limited number of self extracting tools (2 or 3), however a developer might have used any other third party tool (WinZIP, RAR, ...) so you can only cover the most common types.
Launch the setup and monitor the TEMP directory. When the first modal dialog is on the screen the setup files are most likely fully extracted to a sub folder of the TEMP folder. After picking them up from there, you can cancel the setup. Note that some prerequisites may already be installed at that point (e.g. Windows Installer runtime) so if you want to keep your machine clean you should use a virtual machine for this (VirtualPC or VMware).
Posted 07 July 2005 - 10:28
So, there's no way to uncompress the installer exe to get at the files?
Many zip tools (like WinZip) will let you view CAB SFX files, however they can't read an Installshield-generated setup.exe...?
Regards, Simon
Regards, Simon
Posted 07 July 2005 - 11:25
It depends. Some InstallShield self extracting exes (if created with PackageForTheWeb) can be opened with WinZIP. But other don't (they use a different compression algorithm for higher compression rates). If you know it's InstallShield then try /extract_all:<path> to unpack or /a for administrative installation.
Posted 07 July 2005 - 12:43
ok, setup.exe /a /s /v"TARGETDIR=C:\temp /qn" allows me to run an installer executable...however, I can't just run this for any exe our tool locates. Is there any way to detect the following:
1. Is this executable an installshield installer?
2. Is it an InstallScript installer?
3. Is it a basic MSI installer?
Thanks, Simon
Thanks, Simon
Posted 08 July 2005 - 07:59
It may be possible by looking at the version info of the executable.
Posted 08 July 2005 - 13:14
I've tried this, however file version is not reliable because a vendor may change any properties of the installer executable via MSI properties...?
