I'm using ISD 7.04 Standard Project...
In maintenance mode, I have modify and remove option.
When i clicked modify option, I code it to directly run
OnFirstUIBefore. But it have a problem from MSI
1610 - The configuration data for this product is corrupt.
Contact your support personnel.
So, I found out that remove key {PRODUCT_GUID} registry from
HKEY_LOCAL_MACHINE\\SOFTWARE\MICROSOFT\CURRENTVERSION\UNINSTALL\INSTALLSHIELD UNINSTALL INFORMATION
And do modify again, it's runs ok(noerror);
but now, when i remove the installation, it has no error but it didn't remove any file that already installed. I put back the removed registry and run remove installation. It removed.
Finally, i write a code that will add /remove the specific registry according the maintenance selection but this will not work because when launch maintenance mode, the installer first detected the registry before i add/remove it.
How to oversome this matter???
Maintenance Mode Problem
stchin
, Sep 10 2002 10:54
Posted 10 September 2002 - 11:31
Moving post to proper forum
