I am using the below VB script for executing an MSI . This code is running fine inside an VB application.
Set msi = CreateObject("WindowsInstaller.Installer")
' set the UI level to basic
msi.UILevel = 3
' launch the installer
msi.InstallProduct "C:\Packages\Sample App\SampleApp.msi", ""
' clean up
Set msi = Nothing
Iam getting Error 1720 during Installation. Please help me resolving the issue.
Error while executing an MSI inside the Basic MSI
tohareee
, Feb 14 2006 15:02
Posted 15 February 2006 - 13:46
Are you calling this VBScript from a custom action? If yes, in which sequence is it scheduled?
Posted 15 February 2006 - 16:26
I am calling this from VB script custom action. I have scheduled it in execute Sequence of Installation before Install Services. Iam using Install shield 11.5 Premier Edition. I have tried in all position in the sequence. Iam getting the same error.
Posted 18 February 2006 - 10:03
Only one MSi setup can run (in execute sequence) at any time. You cannot launch another MSI setup this way from the Execute sequence.
