since a couple of days I get always an invalid default installation directory for my setup project (this is a basic msi project).
When I start the setup, it will install itself to c:\program files\myinstalldir\program files\myinstalldir (normally it should be installed in c:\program files\myinstalldir).
Of course I can change the directory during the installation, but the problem is that contents of merge modules and other stuff will be still installed to wrong directories. It seems that it recognizes the path c:\program files\myinstalldir as root of the drive.
After hours of checking my project file against our source control system I did not found any difference which could cause the phenomenon. I tried different versions of the project, especially older and previous working versions. I got always the same behavior on my testing machines. Stupidly on my development computer it is running as expected. There seems not to be an pattern behind.
My last try was a new Installation of InstallShield on a different computer. Setups created with this computer are running as expected. (I did not install the Service Packs because I suspect them to cause the problems.)
Any Ideas?
Regards,
Marsyas :confused:
Invalid Installation Dir
Marsyas
, Apr 17 2007 17:56
Posted 30 April 2007 - 10:35
Got it.
I've used a merge module called MFC7.1Config as dependency in another merge module. This causes this strange behavior while it tries to move the standard installation target of the merge module to the installdir.
Marsyas
Marsyas
Posted 20 November 2007 - 07:52
Hello,
The same problem
So, who had the similar problem?
the problem solution please
The same problem
