I want to only install MDAC2.5 on NT4 box but MDAC2.6 on a W2K box. If I use MDAC merge modules provided by InstallShield, how can I modify these merge modules to do the conditional installs?
When I opened the MDAC26.MSM file as an ISWI project, I
found that there are custom actions in the ModuleInstallUISequence and the
ModuleInstallExecuteSequence tables which are then merged with the InstallUISequence and InstallExecuteSequence tables, respectively. How can I change the conditions in these tables to only drop a mdac2.5 on NT4 but MDAC2.6 on w2k? Also can I modify the condition to suppress the reboot from MDAC?
Many thanks in advance!
HJ
How to conditionally install a merge module
hjia
, Dec 06 2002 23:06
Posted 09 December 2002 - 02:14
Merge modules are not really designed to have the complete merge module not installed.
What they do allow is to conditionally set the components to install on a certain condition, or alternatively the feature for the MM to no install.
I would reccommend emailing install shield and ask them if you can add in conditions for the components that they supply in their MM.
Posted 09 December 2002 - 09:26
You could add a condition like
VersionNT<500
on the custom action that installs MDAC 2.5, etc.
VersionNT<500
