Hello everybody,
my IS8 Developer setup works well on the first installation of the product. But as soon as I relaunch the setup and go throug Maintenance Mode "Modify", I receive the "Error -1603 Fatal error during installation. Consult windows Installer Help (Msi.chm) or MSDN for more information" after the file-transfer has finished and MSI is about to clean up his saved files.
How can I find out what the error is about or how to prevent or repair it???
MSI Error -1603
probsar
, Nov 27 2003 15:40
Posted 27 November 2003 - 19:36
First and foremost you should create a log file for your installation, the best is probably to enable the logging policy in the registry (per machine, system policy HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\Installer). Look up the information in the SDK.
Do you have any immediate custom actions inserted after InstallFinalize where the "Ignore error" option isn't checked?
Posted 28 November 2003 - 09:00
I allready got some information from the logfiles. The MSI Installer is going to initiate a reboot and gets back a -1 as result, wich meas he has to reboot (as I can read out of the logs). The option in IS8 in contrary says: Suspend reboot until finished.
Last Log entries MSI:
Property(S): ACTION = INSTALL Property(S): ROOTDRIVE = c:\ Property(S): CostingComplete = 1 Property(S): OutOfDiskSpace = 0 Property(S): OutOfNoRbDiskSpace = 0 Property(S): PrimaryVolumeSpaceAvailable = 0 Property(S): PrimaryVolumeSpaceRequired = 0 Property(S): PrimaryVolumeSpaceRemaining = 0 Property(S): SOURCEDIR = c:\temp\_is2\ Property(S): SourcedirProduct = {790EC520-CCCC-4810-A0FE-061633204CE4} === Logging stopped: 26.11.2003 01:51:29 === MSI (s) (7C:88): Note: 1: 1707 MSI (s) (7C:88): Product: ISScript -- Installation operation completed successfully. MSI (s) (7C:88): Cleaning up uninstalled install packages, if any exist MSI (s) (7C:88): MainEngineThread is returning 0 MSI © (38:BC): Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI © (38:BC): MainEngineThread is returning 0 === Verbose logging stopped: 26.11.2003 01:51:29 === |
Last Log entries IS:
Property(S): ACTION = INSTALL Property(S): ISStartupEvent = E52670 === Protokollierung beendet: 26.11.2003 01:52:06 === MSI (s) (7C:44): Note: 1: 1729 MSI (s) (7C:44): Produkt: DoIt 2000 -- Die Konfiguration ist fehlgeschlagen. MSI (s) (7C:44): Cleaning up uninstalled install packages, if any exist MSI (s) (7C:44): MainEngineThread is returning 1603 MSI © (98:1C): Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI © (98:1C): MainEngineThread is returning 1603 === Verbose logging stopped: 26.11.2003 01:52:07 === === Verbose logging started: 26.11.2003 01:52:07 Build type: SHIP UNICODE 2.00.2600.02 Calling process: c:\Programme\Gemeinsame Dateien\InstallShield\Driver\8\Intel 32\IDriver.exe === === Protokollierung gestartet: 26.11.2003 01:52:07 === Aktion gestartet um 01:52:07: CostInitialize. Aktion beendet um 01:52:07: CostInitialize. Rückgabewert 1. Aktion gestartet um 01:52:07: FileCost. Aktion beendet um 01:52:07: FileCost. Rückgabewert 1. Aktion gestartet um 01:52:07: CostFinalize. Aktion beendet um 01:52:07: CostFinalize. Rückgabewert 1. 1: Installation aborts, ready for RPC shutting down. 1: Invoking __ResetMsiObject... === Verbose logging stopped: 26.11.2003 01:52:09 === |
I still don't know how to manage this. I have some skript actions after this, bu no own CUSTOM ACTIONS...
HE doesn't finish the "Removing backup/save files" as you can recognize in debug Mode of IS where he stops at about 80% of this task and starts one MSI-Engine after one other and NEVER RETURNS...
Thanks for help
