Hello,
The Win2k and XP Add Remove programs dialog box has an icon next to the installed product.
Where do I set this icon within the InstallShield IDE? Different users have different icons when installing my software which is very strange.
Thanks for your help in advance.
Cheers,
Nash
Add Remove Programs Icons
Nash
, Oct 17 2002 18:03
Posted 18 October 2002 - 00:09
Wow, surprised no one answer your question already.
In any case, I also found it to be seemingly random until you have your InstallScript create a string value in the registry which refers to an icon/executable.
That registry location being HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\<YourInstallGUID> and the String value being DisplayIcon whose contents are the fully qualified path to the icon/executable of your choosing.
Posted 18 October 2002 - 15:18
I wrote a brief article, which is posted to this website, that describes many of the entries in the Add/Remove registry for Windows 2000. The truth was already out there.
Blake Miller @ Wonderware
Posted 18 October 2002 - 15:23
Is that the only place to find that icon? The reason I ask is that I thought that's where it would be as well. Then when I went to check on it yesterday, I couldn't find anything about an icon on the registry entries I looked at, yet almost all of the installed programs have their own unique icon. After your answer today I went back and check all 51 entries under Uninstall - only 2 had that registry key! I don't doubt that TB's suggestion does work (it obviously works for 2 of my 51 programs), but there has to be another way the other programs are displaying an icon as well.
Posted 18 October 2002 - 18:24
BMW: Yes, I'm aware of your ARP article. It could use an update though, but yes it does answer this question. There are also several other posts asking this same question which a search would have easily revealed.
I was just surprised no one had responded to at least point to that article given the post had been up for 6 hours at that point.
Xitch13: Yes, my suggestion certainly does work, but I can say what those other entries are doing. This is the only method that I am aware of.
If some those entries are Microsoft created ones well they of course know all the tricks. However, the Windows Installer itself may even have some built-in functions to make this process more seamless thereby explaining some of the other entries. I can't honestly say though since I don't want to touch MSI with a ten foot pole.
Posted 18 October 2002 - 20:39
Hey BMW,
I looked for your article, but was unable to find it. Could you provide a link, or provide a road map for the sometime clueless ones amogst us (me being one of them)
Thnx
Thnx
Posted 18 October 2002 - 22:17
It's under InstallScript Samples, so go to Extensions for InstallShield Pro: Operating System and scroll way down to "Extended Information in Add/Remove Program Control Panel".
However, it has the same DisplayIcon information that I gave you earlier, as well some other values & how they work.
Posted 24 October 2002 - 10:08
Setups installed using Windows Installer technology don't use this entry - MSI has different ways to store the icon.
For non-MSI setups you should use the registry entry already mentioned.
