Hi!
I am trying to insert a new row inside the Control Table. When I enter it manually in Orca there is no problem adding a row, but my SQL query fails for a reason that I ignore.
All other queries works, even those I use for updating a row inside the control table ( Actually, i can update width and type without problem )
Here is my query :
SQL Query - Insert into Control table
frtr
, Aug 31 2004 20:40
Posted 31 August 2004 - 20:40
| "INSERT INTO `Control` VALUES 'CustomTextA','BrowseButton','PushButton','325','120','84','18','3','','{\VSI_MS_Sans_Serif13.0_0_0}&Browse...','','|')" |
As you may see, I am trying to add a BrowseButton to an edit box in the CustomTextA. If you know a simpler way then adding manually a browse button in the control table and other rows in controls events, etc. please feel free to discuss it here
Note : I use Microsoft Visual Studio .net without any authorwares... It's why I use some automated SQL queries as postbuild events on my msi file.
Thanks all for you help!
François Tremblay
Posted 01 September 2004 - 04:29
How are you running this code?? maybe you can check the return value of your function??
Posted 01 September 2004 - 09:57
I see there is a foreign key into the dialog table as part of the primary key for this particular table:
http://msdn.microsof...ntrol_table.asp
I would check that the table ID you are using matches an existing record in the dialog table.
Posted 01 September 2004 - 14:59
I looked on the web site you supplied and I can see that the Dialog_ and Control column are both keys.
However, I have no idea how I can create an entry while respecting those 2 keys...
Can anyone help?
You can try using the WiRunSql.vbs script supplied in the windows installer sdk.
For examples :
SQL Queries examples
Thanks for your help.
Can anyone help?
For examples :
Posted 01 September 2004 - 23:37
What this means is that the controls must be added to an existing dialog. So either create a new dialog and then link to it, or find the name / identifier in the dialog table of an existing dialog and use this identifier in your control table dialog column http://msdn.microsof...ialog_table.asp
Edited by Glytzhkof, 01 September 2004 - 23:40.
