"per machine" installation after "per user"
lavocat
, Jan 19 2006 13:31
Posted 19 January 2006 - 13:31
If I install my setup with "per user" mode in an account X and after I install this setup in an another account with "per machine" mode then if I go back to account X I've to uninstall it twice. Why this?
Posted 19 January 2006 - 13:38
Because you installed twice: for user X and for ALL users. So you have to remove both.
Posted 19 January 2006 - 13:44
So is this normal? is it the case with any setup or should I modify something?
Posted 19 January 2006 - 14:36
yes that's by design and makes a lot fo sense IMHO.
Posted 19 January 2006 - 15:03
all right then
I've a related question.
To prevent error ICE57, I've created a component which put a shortcut on the desktop to the mainapp.exe.
The keypath of this component is a key under HKCU so if I install my app on differents accounts, the shortcut is always created even if the mainapp.exe is already present. But with the above scenario, there is 2 shortcuts on the desktop of the account X because the setup was launched first as per user and after per machine.
Is there a solution to avoid this?
Edited by lavocat, 19 January 2006 - 15:06.
Posted 20 January 2006 - 16:56
I would say "don't install twice if you don't want to have it twice". I guess I don't understand your scenario why you need to install the package twice (first per user then per machine). Maybe you want to enforce a per-machine install, or allow only per-user installs, or display a message during the per-machine install if a per-user install already exists?
