Edited by maximus, 21 October 2010 - 07:16.
remove file from project
maximus
, Oct 21 2010 07:15
Posted 21 October 2010 - 07:15
i want to remove a file from ism project file, after modifying this in project i make one setup.exe . when i upgrade with this setup.exe , old file what i have removed from my project needs to be uninstalled.the file, i want to remove from ism project is in AllOtherFiles in Components. please suggest me the fix thanks in advance
Posted 21 October 2010 - 09:26
As a first step, please find out which project type you are using (you posted this under "InstallScript" and under "Basic MSI"). The project type is displayed in the title bar of the InstallShield IDE when your project is loaded.
Posted 21 October 2010 - 13:56
hi Stefan, I am using Basic msi, and got solution too... i removed file from components section and added record in RemoveFile in Direct Editor for particular file.. :-)
