I've created an install that is a major upgrade to my product. The package code and product code have been changed and the upgrade is being correctly recognized via the upgrade code.
When I run the installation, the existing installation is removed, feature migration occurs correctly and I install all of the correct features without user interaction. However, the install is dropping any property settings on the existing install and replacing them with their defaults.
As such I get behavior like:
MYPRODUCTDIR="C:\Program Files\MyCompanyName\MyProduct" instead of:
MYPRODUCTDIR="C:\Program Files\UserDefinedName\UserDefinedFolder".
Also registry keys that should be:
HKEY_LOCAL_MACHINE\SOFTWARE\MyCompanyName\Val="UserVal" are instead:
HKEY_LOCAL_MACHINE\SOFTWARE\MyCompanyName\Val="DefaultVal"
I assume that I'm missing something simple, but I don't see it. Any incite into this would be greatly appreciated.
Upgrade does not return properties
Aaron_Bashire
, Jul 19 2005 22:51
Posted 20 July 2005 - 16:37
Property values are like variables: they only keep their value while the install is running. They are not persisted (not even for reinstall/repair). You would have to save your property values to registry, abd read them using AppSearch & RegLocator.
Posted 20 July 2005 - 18:06
Stefan,
Yeah, I was starting to come to that conclusion. It just seems like a lot of leg work for something that would seem to be pretty common. As such, I had hoped that there might be a catch-all way of caching these settings for reinstall.
I was planning on following your suggestion if it didn't work out that way. Thanks.
Edited by Aaron_Bashire, 20 July 2005 - 19:03.
