Hello, I've the following problem.
I want to show a variable value in a text field.
The value of the variable is empty at the beginning. It will be shanged through the press on a button. After pressing the button, the text field is not updated. It will be updated, after rejoining the dialog. For any help thanks in advance.
How To refresh a dialog?
GreenValley
, Jan 02 2002 17:17
Posted 04 January 2002 - 10:30
This is one of the most annoying limitaions of the msi interface. The usual method to solve this type of problem is to have a second dialog that looks identical to the first. When the "update" button occurs the changes are made, then the alternate dialog is displayed with the NewDialog event.
Posted 11 January 2002 - 02:51
I've done something simillar to that with an ActionData text field.
Simply make the text field subscribe to the Event :ActionData with attribute Text
Add the name of the custom action to the ActionText table and provide a template like: [1] where [1] will be replaced with your message.
In your custom action when you get the value if your using installscript use MsiProcessMessage with the
INSTALLMESSAGE_ACTIONDATA message type. You would format the message simillar to how you write to the windows installer log file.
That should give you the results your looking for.
