Installshield 12
specialhaha
, Feb 17 2009 16:42
6 replies to this topic
Posted 17 February 2009 - 16:42
Hi all,
I'd like to do this :
- Unzip the external file (zip format or CAB format)
- This file contents the data.
- After unzipping, I must copy these directories, files into harddisk
I don't know how to do this
Many thanks for your help
Posted 19 February 2009 - 21:27
There are DLL libraries and similar tools (I believe some are freeware) for unzipping files that you could use.
Posted 23 February 2009 - 14:12
Many thanks for your answer.
but where are they?
I couldn't find them
Thanks in advance
but where are they?
Thanks in advance
Posted 25 February 2009 - 14:19
Enter "unzip DLL" or "unzip library" in your preferred internet search engine. That's what I would do anyway, sionce I don't have any links at hand.
Posted 12 March 2009 - 20:03
Posted 22 August 2011 - 17:10
Don't unzip as part of the setup. Instead implement the unzip as part of your first application launch. With the main application EXE you have much more control of the unzip operation in terms of exception handling, and you ensure that the unzip is happening in the context of the right user. Just install the zip files to a per machine location and then have the application unzip the files to the required destinations in the user profile. Add a flag to the registry for the user in question when the unzip is completed.
