Hi
We are facing problem in running the Setup from One click Install we are reciving javascript error in Internet Explorer with followig details:
Line: 52
Error: "Invalid Procedure call or Argument"
Following code is generated by Installshield causing problem:
One Click Install - SetSetupType Error
nitinmahajan10
, Jun 21 2005 16:25
Posted 21 June 2005 - 16:25
// App not installed, set TargetDir and setup type if (!ether.IsInstalled()) { var strTargetDir = ether.GetTextSub("PROGRAMFILES") + ether.ProductName; ether.SetTargetDir(strTargetDir); ether.SetSetupType("Typical"); //Line 52 |
Error is caused by statement "ether.SetSetupType("Typical"); ". When we comment this statement We don't get javascript error but then setup does not run properly i.e. it does not installs the product.
What could be the solution?? Please Help !!!
Nitin
Posted 22 June 2005 - 17:19
I haven't used IS 6 in a while, but I think in later versions of InstallShield the SetTargetDir has been removed (replaced by some other means to set the directory). Therefore I suspect that your version of the ether object may not be correct (i.e. trying to run old script with new ether)
Posted 28 June 2005 - 12:45
Thanks a Lot Stefan
My problem was with the line No. 52 ::: SetSetupType("Typical");
Default "Typical" Setup Type was not available in Project. So know this is working fine for know.
Nitin
Nitin
