I have a IS6.3 Installation-Routine, which I use for fresh Installs, Updates and Maintenance Tasks - all in one.
Most of the Events are caught and proceeded by hand, so I really control them
Now I'd like to add an additional functionality with silent mode setup, to ease the remote distribution for our FE's.
For that I have generated a *.iss file with "setup.exe -r". Within this process I recognized that each single 'Action' is listened in numeric order from 0 to X. (e.g. Dlg1, Dlg2, ... and beneath the encoding [{ProductGUID}-SdShowDlgEdit3-0] Part of the .iss files)
Now my problem is that the different installation processes (fresh, Maintenance and Update) also have different .iss files (different sequences for the same dialogs). E.g. the Dialogs of Licensing and User Information's and so on will not be displayed in maintenance or update mode but different additional dialogs might appear instead (maintenance dialog) instead of those.
This means I would have to provide a own .iss file for each possible run-through (about 12) of the setup. This is not acceptable for maintaining and distributing the Installer to be used by our FE's.
How can I produce and USE a generally valid .iss file for this kind of installation type???
