During RemoveExistingProducts action (when major upgrade being applyed) some files where scheduled for remove after restart. But these files (dll's) required for CA in InstallExecute sequence of upgrade. This problem cause fault of upgrade process. Can I pause upgrade with system restart and then installation will continue? Is there another way to resolve this prblem?
Files locked during upgrade
igodunov
, Dec 28 2005 08:58
Posted 28 December 2005 - 13:54
Yes you can insert a ForceReboot action to request a reboot and continue after the reboot.
Posted 28 December 2005 - 18:40
Thanx! It's really good idea! But, can I set gui level to "base" for "after-reboot" installation in some way or it is necessary to use NOT AFTERREBOOT condition for each step of InstallUISequence?
Posted 29 December 2005 - 13:38
You need to use Not AFTERREBOOT on any action that you don't want to run again. In most cases, it will be sufficient to use this on the Welcome dialog.
Posted 29 December 2005 - 16:35
Thank you very much!
I just found simple solution for my problem - scheduling RemoveExistingProducts after InstallFinilize prevents file locks.
