incorrect command line parameters
pant
, Oct 03 2004 21:29
11 replies to this topic
Posted 03 October 2004 - 21:29
whenever i try to execute msiexec.exe or any *.msi i get "incorrect command line parameters" dialog. In services its parameter is /V and its started. win2k sp4 & msiexec 2.00.2600.1183. Thanks
Posted 05 October 2004 - 09:12
Are you installing from the local hard disk, from CD or from network?
Do you have an AppSearch in your setup that searches for a registry entry that might return a multi-line value?
Posted 06 October 2004 - 15:25
Thank you.
I'm installing from the local hard disk, witch is not the system disk, still it doesn't help if I copied the file to windows disk.
No, the above dialog is given without an appsearch. Dialog is given "momentally".
Posted 07 October 2004 - 09:15
If your MSI file name contains spaces, make sure you double-quote this name in the command-line.
Posted 07 October 2004 - 11:02
It's not about any msi file in particular. The msiexec.exe itself gives the same answer- for no input maybe?
Posted 07 October 2004 - 18:03
if you launch msiexec with no parameters, it will always bring up that dialog that tells you what parameters to use.
Posted 08 October 2004 - 21:38
Launching msiexec.exe gives me the above dialog, with no parameter hints. Only trelling me tahat JPEG incorporated has connections with Windows Installer.
Posted 09 October 2004 - 11:23
....and the version number. That's true. This has changed in MSI 3 where it tells you about the command line parameters. But you can always look them up in the documentation.
Posted 11 October 2004 - 09:59
No, this would only change the error message. You need to find out why starting an install brtings up that message.
Did you look at Zweitze's suggestion?
Generate a log file to see what the exact command line is.
Posted 05 November 2004 - 12:39
Thank you very much for your effort. I was trying to get that logfile you suggested today and instead error I got installation. I had never tried to install from command line before. I was just clicking on the installer package. Thank you again.
