i assigned my msi installer in group policy and set it to autoinstall upon logon of user.
When the user logson...the load screen says installing the managed MSI installer..
then it hangs there..ive waited for about an hour and nothing happens, then i reboot the pc..and no application is installed..i guess it doesnt run the installation..
can any one tell me whats the cause of this scenario?
i have CA running in deffered in system context and also i have some CA that is in immediate execution but it is on the UI sequence.
is it possible that the CA cause this problem? I dont know how to debug this problem.
Thank you in advance
Grpup policy MSI installation Hangs
haroldxious
, Jun 05 2007 08:27
Posted 05 September 2007 - 12:17
I have recently seen similar scenario, without solution so far.
Glytzhkof, interesting thing is that there is no log created in such case. In processes it shows that msiexec is running. I have tried with a Logging registry entry with value '!xvoicewarmup'.
And, if you have some file in SUPPORTDIR they are extracted to temp folder.
ankur tyagi
