Is this a bug in the installer? I can't believe it's a feature.
Is there a workaround apart from deleting the bitmap?
Buttons Over Bitmaps - Newbie
gowen
, May 04 2001 14:58
Posted 04 May 2001 - 14:58
I would like to use a bitmap as a background to a dialog with text and buttons on top of it. It looks fine in the dialog editor, but when I run the install, the buttons disappear under the bitmap until you click over them. The text stays visible.
Posted 04 May 2001 - 20:59
Make sure that buttons have a higher tab order than the bitmap, and make sure the bitmap has the tab stop set to yes.
