I am using standalone build 2011 to build an ism project and get the following error.
ISDEV : fatal error -5002: Product Configuration 'Product Configuration 1' is not found in the specified project. Verify that the Product Configuration name is correct.
This used to work fine with dev studio 2009.
Any idea how I could resolve this issue?
Standalone build 2011 error
pinto.jitesh
, Jan 17 2012 13:52
Posted 17 January 2012 - 15:08
Does the build work from the IDE? Does the product configuration with that name actually exist in the project?
Posted 18 January 2012 - 06:14
Yes it works with the IDE.
I get the error if i build using the command
C:\Program Files\Installshield\2011 SAB\System\IsCmdBld.exe (-p c:\Perforce\mt\mt\5.17_COR\ext\Installation\Ehp1_SP05\Ehp1\Source\Project\PDG505SP00.ism -r "Release 1" -a "Product Configuration 1" -b <PATH>\CRMMobile.msi -t C:\Windows\Microsoft.NET\Framework\v2.0.50727 -j 2.0.50727 -e n)' in 'C:\Perforce\mt\mt\dev_int\Installation\AutomationScripts\Ehp1\SP05\MainAutomation\Batches'
Posted 26 January 2012 - 13:40
Not sure what the problem is then. Are you using the SAB on the same machine as the InstallShield IDE? Does building from InstallShield command line built (not the stand-alone build tool) work?
