Problem:
If I a use different Targets (defined in the directory table), I can install to diffrent locations, but I found no way to 'synchronize' this folders with INSTALLDIR.
If I use constructs like '[INSTALLDIR]\data' for the subfeatures, the target forlders are 'synchronized' with INSTALLDIR. Though I'm able to change the Targetfolder for single subfeature, it's always installed under the INSTALLDIR.
Is there any solution for this problem? Are my attempts complete wrong?
Thank you for any answer.
