Has anyone on this board successfully prototyped SQLDataSources in ODBC32.DLL? This prototype is not in Winapi.h, so I need to make one.
The return value is suppose to be '1' upon success, but I always get '65534' when it is called.
Below is the InstallScript prototype I am currently working with:
// --- API call to "SQLDataSources" in ODBC32.DLL
prototype ODBC32.SQLDataSources (HWND, NUMBER, BYVAL STRING, NUMBER, NUMBER, BYVAL STRING, NUMBER, NUMBER);
Below is the MicroSoft explanation of the format:
SQLRETURN SQLDataSources(
SQLHENV EnvironmentHandle,
SQLUSMALLINT Direction,
SQLCHAR * ServerName,
SQLSMALLINT BufferLength1,
SQLSMALLINT * NameLength1Ptr,
SQLCHAR * Description,
SQLSMALLINT BufferLength2,
SQLSMALLINT * NameLength2Ptr);
I have successfully run the following prototype in Visual Basic 6.0:
Private Declare Function SQLDataSources Lib "ODBC32.DLL" (ByVal henv&, ByVal fDirection%, ByVal szDSN$, ByVal cbDSNMax%, pcbDSN%, ByVal szDescription$, ByVal cbDescriptionMax%, pcbDescription%) As Integer
Any brave souls out there?
Trying to prototype SQLDataSource
Ozone
, Oct 18 2006 20:45
Posted 19 October 2006 - 16:09
By trial and error, I have the working prototype! (more error than trial)
prototype ODBC32.SQLDataSources (BYVAL HWND, INT, BYREF STRING, INT, BYREF INT, BYREF STRING, INT, BYREF INT);
I need to buy a lottery ticket today!
Posted 19 October 2006 - 17:18
The code for those of you who want a working model....
| //////////////////////////////////////////////////////////////////////////////// // // Purpose: To get DSN's // // Last Updated: 10-17-2006 - OZONE - Created // //////////////////////////////////////////////////////////////////////////////// // --- API call to "SQLDataSources" in ODBC32.DLL prototype ODBC32.SQLDataSources (BYVAL HWND, INT, BYREF STRING, INT, BYREF INT, BYREF STRING, INT, BYREF INT); // --- API call to "SQLAllocEnv" in ODBC32.DLL prototype ODBC32.SQLAllocEnv (BYREF HWND); // -- Prototype this Function prototype Get_DSNs(); #define SQL_SUCCESS 0 #define SQL_FETCH_NEXT 1 // -- Begin function here function Get_DSNs() INT i, iDSNLen, iDRVLen; STRING sDSNItem[1024], sDRVItem[1024]; STRING sDSN, sDRV; HWND lHenv; begin //--- get the DSNs if SQLAllocEnv(lHenv) != -1 then while i = SQL_SUCCESS i = SQLDataSources(lHenv, SQL_FETCH_NEXT, sDSNItem, 1024, iDSNLen, sDRVItem, 1024, iDRVLen); StrSub ( sDSN, sDSNItem, 0, iDSNLen ); StrSub ( sDRV, sDRVItem, 0, iDRVLen ); // Filter the type of database that you want to display if sDRV = "Pervasive ODBC Engine Interface" then MessageBox( "DRIVER = " + sDRV + "\n\nDSN = " + sDSN , INFORMATION); elseif sDRV = "SQL Server" then MessageBox( "DRIVER = " + sDRV + "\n\nDSN = " + sDSN , INFORMATION); elseif sDRV = "Microsoft ODBC for Oracle" then MessageBox( "DRIVER = " + sDRV + "\n\nDSN = " + sDSN , INFORMATION); endif; endwhile; endif; end; |
