Hi there,
Our product installs with a set of localized (English or Japanese) registry values, so that the user can change the app's default text in certain places. This is how we do it:
(In the string table)
IDS_MY_STRING - a string resource that has English and Japanese translations.
(In the Property table)
PropMyString - a private property, whose value is {IDS_MY_STRING} to get the localized string resource.
(In the Registry table)
MyRegValue - a registry entry, whose value is [PropMyString] to get the initialized property.
This approach works perfectly for a fresh install, but if I perform a Japanese upgrade then any new registry values get written as English. If I do an MsiGetProperty() during the install, then I find that PropMyString always holds the English string, and if I try to hack it by doing MsiSetProperty(PropMyString, @IDS_MY_STRING) from a script CA in InstallExecute then the property changes, but the registry value still comes out in English.
Does anyone have any ideas?
Karim
Localizable registry values upgrade problem
Karim.MacDonald
, Feb 16 2006 21:28
Posted 21 February 2006 - 04:09
(Addendum)
Oh well, no joy. If anyone else ever has this prob, I'm afraid I gave up, tho' you might try your luck with public (all-caps) properties. I've decided to let the app create the registry entries on first usage, which gives more robust behaviour anyway
btw, product used was IS Developer 7.04
