Dear all,
I need to run my patch package with the following command :
<drive>:\updade.exe /v"CMDLINE=boot"
If I execute that command line above from the Start->Run uner windows it executes well.
Before executing that command I need to do some stuff and reboot , then proceed again. for that I place that comamnd line inside script to write to registry key RUNONCE. Then before it reboots I verify that the key is properly created with correct syntax, whic is the case
At the next reboot, the runonce key is executed and at that time Installer return are error message saying that line parameter is invalid.
I copie then the same line and paste it to the Start->Run it fires correctly..
What is going wrong here ?
Thanks for your help
Serge
Using command line for passing parameters??
calderaraserge
, Sep 22 2004 13:16
