I want to add my own error messages to the error table, but how can I get the text for error message to be loaded from the string table? That way it can be translated along with the rest of my strings.
Anthony
Adding strings to the error table
anthonyh
, Nov 18 2002 22:20
Posted 18 November 2002 - 22:20
Product Availability Developer
Avantis
Invensys Process Systems
Using InstallShield Developer 7.04 - Basic Project
Avantis
Posted 19 November 2002 - 10:58
The error messages are in the Error table. If you add a new error message into this table, you will get an entry in the ISString table which follows the rule ID_STRING_xxx where xxx is a number. In the ISString table you can export and translate the strings. For every language the new error will have the identifier ID_STRING_xxx but with a different language ID. The language you enter in the error table should be the language you set as default language for your project.
Barbara
Barbara
The difference between theory and practice is larger in practice than in the theory.
Posted 19 November 2002 - 15:20
Thanks. That's what I was hoping for.
Anthony
Anthony
Avantis
Avantis
