I have build a merge module with a CA, do I have to call
this CA inside my main setup or is it called automaticly ?
thanks for your help
Posted 05 July 2001 - 09:37
Posted 10 July 2001 - 09:33
Posted 28 November 2001 - 19:19
I have same issue here.
If it is not listed in custom Action table how do I make it in custom Action Table?
Basically I have created Merge module which contains a executable in Binary table. I do not want to include this executable part of any components as this executable should be run only once during installation and has some *condition*.
This executable should be part of merge module and Merge module do not have any other files.
I have created a custom action which is part of merge module. I did not see any way I can add a sequence in Mergemodule.
I have created a Project and included this Merge module. After build I did not see the custom action which is part of merge module in the msi file. Is their any solution to add custiom action and Condition?
Posted 14 February 2002 - 02:01
Hope this helps...
Posted 14 February 2002 - 08:33
Action: Your custom action name.moduleid (from General Information->MergeModule Properties), but using underscores instead of dashes.
i.e. MyCustomAction.B3D45BE0_7369_4B50_BCE7_9973B3B55FB3
Sequence: 0
BaseAction: CostFinalize
After: 1
Then, you have to add the CostFinalize action, too (even though it is in the main sequence).
Sequence: 500
BaseAction: Empty
After: 0
PS: These are just my "working notes" on how to do this - I must stress that I am just learning CA's and conditions myself...
