Hello
I want to disable the Modify option in the Maintenance Type Dialog.
If I delete the radio button, icon and text field when I run the setup in Maintenance mode then neither of the remaining radio buttons (Repair and Remove) is selected.
If I don't select one and just click Next then it still acts as though Modify was selected.
Is it possible to change the default to be Repair or Remove instead of Modify?
Or is there a way to disable Modify without deleting the controls from the dialog?
Disable Modify in Maintenance Type Dialog
Seany
, Aug 16 2012 17:24
Posted 16 August 2012 - 22:25
Go to Property Manager and change the value of _IsMaintenance to Reinstall (for repair) or Remove instead of Change.
Posted 17 August 2012 - 09:14
Hi
Thankyou very much for your reply.
Did you mean the Property manager of the 'Next' button in the Behaviour section of the Maintenance Type dialog?
I tried this and built my installshield, it seemed to have no effect and when I went back in the values I had amended to 'Reinstall' had all reverted back to 'Change'!
I hadnt at this time deleted the Modify radio button, do I need to do that for this to work?
Posted 17 August 2012 - 12:10
No, I'm talking about the Property Manager where you set the default value for all properties. You can find it (in Installaton Designer) in the left hand pane under "Behavior and Logic". There's an item called "Property Manager".
