I need some help with upgrades...
I have an installer that works fine upon first being run on a clean machine. Everything gets installed as it should. I am using one Setup.exe file, fyi. When we do a nightly build and the next morning we try to install it on the test server by running the new setup.exe file, a dialog pops up saying that it's going to perform an upgrade, so far so good...
I set a registry value under HKLM\Software\MyCompany\MyProduct\Version which gets set to [ProductVersion]. I do this via the IDE in IS8. The only problem is, this value isn't updated when performing an upgrade. The value obviously is changing, because we change the value of [ProductVersion] with every build, so why is the new key not being created? I am pulling my hair out over just trying to set a simple registry key to a string value and have it updated.
Any help you can provide on this issue or upgrades in general would be much appreciated,
Thanks in advance,
Jacob438
Minor Upgrade help
Jacob438
, Aug 04 2003 21:31
Posted 05 August 2003 - 10:21
What's the key path of the component that contains this registry entry? It should only be overwritten if the key path needs to be overwritten.
