I created a custom action with the following feature:
Type=34
Source=SystemFolder
Target=cmd \c d:\thedosprg.exe
to call a dos program.
During run time, i got this following error:
Internal Error 2744. Customer_Action_NAme,
C:\winnt\system32\, cmd /c d:\thedosprg.exe
Can anybody help?
KC
Calling Dos program
post2kc
, Jun 06 2002 12:02
Posted 10 June 2002 - 08:36
There are two things that I would change in your CA:
- CMD is not simply CMD; it's CMD.EXE
- Change your custom action to ignore the return code (add 64 to your CA-type) -> 34+64=98 if your dosapp doesn't return the right return values needed by MSI.
For further info about return codes in msi-installations look for "Custom Action Return Processing Options" and "Custom Action Return Values" in the windows installer documentation (msi.chm)
h.teichert-ott
Posted 10 June 2002 - 08:47
Aaah, I forgot:
Your custom action only works on NT, W2K and XP; but not on the Win9x systems. The command line interpreter on 9x is called "command.com", not "cmd.exe". When you want to create a CA that works on all systems, it's necessary to search for the current commandline interpreter - it can be found in the environment variable "comspec".
h.teichert-ott
