I am working on a InstallScript project in which I need to install Crystal Reports runtime for .NET 2.0 framework on the end users machine. I downloaded the required merge module from BusinessObjects website and incorporated in my setup. But during installation this merge module gives an error: "1: ALLUSERS property is not 1 - the MSM cannot be used for a per-user or fallback-to-per-user install 2: 2"
The installation is being carried out under Administrative privileges and all the other files and short cuts in the project are getting copied for all users.
I tried setting ALLUSERS=1 in installscript as well as the property table but it did not work.
The merge module was downloaded from the following location:
Crystal Report Merge Module
Vaibhav
Crystal Reports merge module and ALLUSERS property
Vaibhav.Goel
, May 29 2006 10:21
Posted 29 May 2006 - 17:30
Maybe the value of ALLUSERS is not forwarded to the merge module holder object (I never tried this). As a workaround create a Basic MSI project that only includes the Crystal modules and set ALLUSERS to 1 in the Property manager. Then include this msi setup in your InstallScript setup (basically that's what the merge module holder object does).
Posted 12 June 2006 - 06:14
Thanx for the reply Stefan.
This is a response that I got from Macrovision forum and it works:
http://community.mac...t=155906&page=2
Though the soution given is for Installshield 11.5 but it works for 11 as well.
Vaibhav
Vaibhav
Posted 21 June 2006 - 07:34
Thanks Vaibhav. the link helped me to solve the problem I was getting while adding VC++ runtime objects.
Thanks again for the link !
Posted 29 September 2008 - 21:29
Although this post is over 2 years since the last, I'd like to also thank you for this solution!
Does anyone know of a more permanent and proper fix for this? This seems to be more of a workaround since it requires a manual tweak to an included MSI package.
Is it a bug either with Installshield or Microsoft (since it's an MSI package?)
