Has anyone got advertisement to work properly? I have tried, but when I run the install from the advertised shortcut it says something like:
Problem with the shortcut
Unable to execute command
I'm beginning to be desperate here. If shortcut advertisement it would be just as good if the program could be advertised in the add/remove applet.
You can't select which features are going to be installed or advertised in my program from the setup. Everything is installed or advertised at the same time. Advertisement is done from the commandline with msiexec /j installer.msi.
Advertisement
OKauhanen
, Jun 07 2001 08:16
