I am doing my first Install Shield Basic MSI installer. I need to do some specific things when my product is uninstalled. This requires a GUI.
One thing I need to do is to collect a password from the user. I was able to do this by calling the Iscript function "EnterPassword". The dialog is kind of ugly though and I'd like the flexibility of making changes to it. Does anyone know how?
I will in a month or two have to do a lot more UI. We want to allow users to choose between uninstalling the whole package, or reverting to the free, and less functional package. This will require more complicated dialogs.
If anyone has ideas about how to put together a more complex UI for uninstall please let me know.
I've tried to figure out how to put diologs into the execute sequence (which is all that seems to run when the user clicks "Remove"), but haven't had any success.
Thanks for any help you can provide.
-Bob
User Interface on Uninstall
bobinsf
, Jan 07 2004 03:15
Posted 07 January 2004 - 03:42
I am afraid I have some bad news for you: Installshield automatically skips the entire user interface sequence when you select Remove from "Add/Remove programs". Here is some more info:
http://community.ins...threadid=128008
It is not possible to insert dialogs in the execute sequence. I believe you can disable the "Remove" button and keep only the "Change" button. But I seem to recall that this causes the unfortunate side-effect that there are no buttons in add/remove at all on some operating systems...
Posted 07 January 2004 - 19:08
What were they thinking. I guess I'm off to write some dialogs in C++ and put them in a dll.
Or maybe I should learn more about IScript. If I can edit resources on the dialogs that EnterPassword uses (and other such functions) then I can cobble this together.
Thanks for the input.
-Bob
Posted 08 January 2004 - 08:40
As Glytzhkof suggested you can disable the Remove button in control panel. You can do this by setting ARPNOREMOVE in a custom action that only executes on Windows 2000 and above to avoid the mentioned problem on older operating systems.
