I'm currently running IS 7.1, and all our installs always show up behind any other windows that open at launch. This is a major problem for both DemoShield launched and web launched installs. Apparently this is a known IS 7 bug.
I've tried 2 workarounds to force the window to gain focus, neither of which seems to work. They are:
1 - Suggested by IS) SdShowMessage("",FALSE);
2) HWND installWindow;
begin
installWindow=GetWindowHandle(HWND_INSTALL);
SetFocus(installWindow);
Both of these compile fine, make the taskbar flash like they should, but the window remains behind. Any one have any suggestions?
Need cute way to bring focus to Install
prozacrefugee
, Feb 18 2003 22:43
Posted 28 February 2003 - 20:29
We found the problem with the installer window starting in the background/losing focus started happening when we first used skins.
If you're using skins, you might solve the problem by removing them. It's a tradeoff.
In your code sample, did you mean SetForegroundWindow?
I'm surprised that IS knows about the problem, but there is nothing in their knowledge base that I could find.
Posted 03 March 2003 - 18:36
Yes, I meant SetForeground.
Thanks for the tip on the skins, I'll give that a try.
I couldn't find this on the InstallShield site either - their tech support informed me it was a known issue.
Thanks again!
Thanks again!
