Hi folks,
our program will generate some files during runtime. These files are meant to be user-independent and we are generating them into our installpath, e.g:
c:\Program Files\OurApp\
This is by design and works fine for our needs under WinXP and W2K. As you can image, the Vista security mechanism UAC is not happy with our way, normal users can't even start our application because they do not have the rights to write into our folder mentioned above.
So what we tried is to set new rights on the installpath using WISE 7.0, that everyone on this computer is able to read, write and delete files from our installpath or paths below that.
Is this the correct way to solve this problem our is this just a workaround we shoulnd't use?
What is the best way to deal with files generated by the application itself using Vista from the view of the setup developer?
Kindest regards,
Torben
MSI under Windows Vista. Best practise question
Torben
, Nov 24 2008 13:38
Posted 24 November 2008 - 14:35
It's a workaround which is not recommended because this would enable users (or malware that runs in their context) to modify your executables.
Instead you should store these files in a user writable location, maybe under C:\ProgramData (a hidden directory).
Posted 24 November 2008 - 14:58
How about installing it to a folder inside programfilesfolder
and then setting rights on this folder using Wise so that
everyone on this computer can write to this folder or folders
below that
Posted 24 November 2008 - 15:54
| QUOTE (Stefan Krueger @ 2008-11-24 13:35) |
| It's a workaround which is not recommended because this would enable users (or malware that runs in their context) to modify your executables. Instead you should store these files in a user writable location, maybe under C:\ProgramData (a hidden directory). |
Thank both of you very much.
Stefan, what you wrote is what I was afraid to read :-)
This would mean that we have to restructure our application in many varieties.
Could the following way work?
When we start our application from the desktops icon using "Windows XP SP2"-compatibility mode and run it as administrator, it should work fine, I guess.
Since we are using WISE 7.0, I have no idea how to enable the features mentioned above in our installation.
Kindest regards,
Torben
Posted 24 November 2008 - 16:11
Isn't this sort of thing the entire reason MS created the 'Application Data' structures beneath the profile folders? IMV (as an erstwhile developer), it's always been bad practice to place user-writeable files into the 'Program Files' area.
Posted 24 November 2008 - 17:59
| QUOTE (VBScab @ 2008-11-24 15:11) |
| Isn't this sort of thing the entire reason MS created the 'Application Data' structures beneath the profile folders? IMV (as an erstwhile developer), it's always been bad practice to place user-writeable files into the 'Program Files' area. |
You're completly right, no doubt.
We inherited this project and I must admit that we simply forgot to correct this malformed structure from the start.
