Hi...
I am using Visual Studio Installer for creating an .msi package.
In the registtry settings window I have added the following key:-
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment
In this I have specified the following:-
Data Type: vsirdtREG_SZ
Value : [~];C:\Winfcp\Exe
The msi package created using this doesn't get the environment path properly from system properly.
Therefore if the path was :
C:\Winnt\System32
it becomes:-
;C:\Winfcp\Exe
Also when I uninstall this package the "Path" environment is removed from the registry.
My problem is :-
1) How do i add onto the current Environment path
2) During uninstall, how do I force the uninstaller to revert back to the previous Environment path value.
Any help would be greatly appreciated.
Vinay
Registry key is removed during uninstall?
vinaychandran
, Apr 29 2002 05:33
Posted 12 October 2005 - 04:30
Is there anyone that has the answer to this?
This is basically the same question that I was going to ask.
I got all happy when I found in the search only to find that there are no replies
I understand that using software such as installshield has these options but I'd like to know if it can be done using the VS.Net installer.
Wes
Wes
Posted 12 October 2005 - 05:38
ok,
I think I found the answer to the above problem by editing the environment table with this:
Environment: Path
Value: [~];[INSTALLDIR]
But, I am unsure of what to put in the component_ field?
Any ideas?
I am using ORCA to edit the environment table.
Environment: Path
Any ideas?
Edited by Wesley Paik, 12 October 2005 - 05:39.
Posted 12 October 2005 - 11:23
The component that should trigger the installation of that entry.
When you try to edit a relational database with a low level table viewer should should carefully read the documentation about the affected tables to avoid corruption.
