Hi all.
I need to transfer Win32 made controls and dialogs to InstallScript.
I found that the only way to do it is to use the DefineDialog with DLG_MSG_ALL.
But in this case WaitOnDialog still filters all "unnecessary" messages.
The following IS code is stuck after GetMessage function:
Organize message loop without WaitOnDialog
mirik222
, Sep 09 2010 19:10
Posted 09 September 2010 - 19:10
| DefineDialog (szDialog, NULL, "",DIALOG_ID, "", NULL, HWND_INSTALL, DLG_MSG_ALL|DLG_CENTERED); hwndDlg = FindWindow("","installshield wizard"); ShowWindow(hwndDlg,SW_SHOW); UpdateWindow(hwndDlg); GetMessage(&msg,NULL,0,0); |
What am I doing wrong?
Edited by mirik222, 10 September 2010 - 20:38.
Posted 16 October 2010 - 17:08
The problem was in catching custom control messages and is partly solved.
The dialog should be created by DefineDialog instead of the standard EzDefineDialog.
| if(DefineDialog( szDlg, 0, "", SD_NDLG_WELCOME,"",0,HWND_INSTALL,DLG_MSG_ALL|DLG_CENTERED ) = DLG_ERR) then return -1; endif; |
Then, the events are caught by the regular way, with switch/case block:
| case 1301: ret = SendMessage(hListWnd, LVM_GETNEXTITEM, -1, LVIS_SELECTED); if(ret > -1) then lvit.mask = LVIF_TEXT; lvit.iItem = ret; lvit.iSubItem = 0; lvit.pszText = &szListText; lvit.cchTextMax = MAX_PATH; SendMessage(hListWnd, LVM_GETITEMTEXT, ret, &lvit); pstr = lvit.pszText; szItemName = pstr->str; endif; |
PSTR structure is defined for pointer resolution. I didn't find how to do it in InstallScript.
| typedef PSTR begin string str[MAX_PATH]; end; |
Edited by mirik222, 16 October 2010 - 17:11.
