WI 2.03 build generates 1033.msi and setup.exe in the Disk1 when i build a network image with compressed all. The 1033.msi causes the setup fail to run properly for example the setup run without dialog.
How can I build properly without generating 1033.msi?
1033.msi in the build
lavinia
, Oct 01 2001 23:14
Posted 01 November 2001 - 23:53
I am hoping to find the answer to this question as well. On my dev machine, I build my setup via a batch file (essentially compiling it via the command line). However every so often I get this bug where there is a 1033.msi and my expected msi file name. Neither of them are valid setups.
Luckly I have not had the problem on the nightly build machine (also compiles via the same batch file).
The only solution I found was to open the .ism and delete all the entries in the Release section of InstallShield, and then use the Release Wizard to create a new one. Then I can exit and run the batch file, usually with success.
