Could someone please help me??
I am pulling my hair out on this topic...
I am using the Installation package inside of VS 2003 .NET. (Maybe this is the wrong place for this question).
What I am trying to do it to make an installation package for a seperate program that is basically an "add-in" for the main application. To install the add-in, I need to read the TARGETDIR from the main app, and install the add-in files into it. My problem is that I can't seem to find out how to read in the TARGETDIR from the Main app and set the TARGETDIR/new folder for the Add-IN. Is it even possible to read? I've even tried reading a registry entry, that doesn't work.
Thanks for any help!
Todd
using Windows Installer as a Add-in installer
toddp
, Sep 30 2004 19:23
Posted 01 October 2004 - 10:53
moving question to MSI forum
Posted 01 October 2004 - 10:55
If your main setup launches that add-in setup you could pass TARGETDIR on the command line.
Otherwise your add-in setup would have to read TARGETDIR from somewhere, e.g. from a registry entry. If you tried to read and it didn't work: did you verify using regedit that the entry is there? how did you read, and when?
