I build setup for a product, every component has a key file.
After installing this product, when i look into following registry key:
HKLM > Microsoft > Windows > CurrentVersion > Installer > UserData > s-1-5-18 > Components > guid_of_my_component
the path displayed under this registry is strange for few components.
instead of
Strange path
antyagi
, Apr 10 2006 08:36
6 replies to this topic
Posted 10 April 2006 - 08:36
| C:\Program Files\MyProduct... |
it displays
| C?\Program Files\MyProduct... |
or
| xx\Program Files\MyProduct... |
(replace xx with 2 digit random number)
Can someone explain why/when the path is written to registry like this?
And, how to analyze this path?
ankur
ankur
ankur tyagi
Posted 19 April 2006 - 06:10
I have some of those in my registry as well, i just never realized that they were there!
Maybe is has something to do with the component attributes?
Posted 19 April 2006 - 06:53
First thought that strikes me was same, component attributes may be responsible for this. But when i compared two different compnents in my project, both components have exactly similar attributes.
however path of one is displayed in registry as
and that of other as
This is creating problem for me because i have some other product which may be reading path from these registry keys.
Can someone knows reason for this ??
ankur tyagi
Posted 19 April 2006 - 06:58
I have a finding...
When a component does not have a key file, the path in registry is
But if I set the file, say xyz.ext as key file for component the path in registry is
why....
ankur tyagi
Posted 19 April 2006 - 06:59
Products really shouldnt be reading directly from this key, because the location could change, and did change between earlier versions of Windows Installer. So it might do so in future versions as well.
You should be using MsiGetComponentPath or MsiLocateComponent. If these functions return the "?" in the string, then this is a problem and should be raised for the Windows Installer team.
Posted 04 May 2006 - 12:24
I am back
My problem is not resolved.
Actually i was using MsiLocateComponent.
However, when i looked at MsiGetComponentPath it also give the same results.
But see the description of MsiGetComponentPath in WI SDK, it explains the meaning of 'xx' in
And as we have earlier found the reason of '?' in
So i think this topic is complete
ankur tyagi
Posted 04 May 2006 - 12:25
My problem was resolved. It was typo in first line of last posting.
ankur tyagi
