Hi
I need to build a setup for a .Net application using Windows Installer 2.03. I need to include .Net assemblies. How can I do that ?
I read in the MSI help that I need to modify the MSIAssembly and MSIAssemblyName tables through Orca. When I open the MSI, I do not see these tables.
Any help would be appreciated.
.net and IPWI 2.03
gg
, May 22 2002 15:06
Posted 25 May 2002 - 18:21
gg,
When in Orca, right-click in the left hand column and select "Add Table" or Ctrl-T. You should find both these tables listed.
I have a feeling that these tables are supported in 2.0 onwards, so you may need to change your schema under the Summary Information View to "200". This is from memory though so I could be wrong
If in doubt, consult the MSI.chm (aka THE BIBLE) that is available with the SDK
Hope this helps.
Adam
Hope this helps.
Adam
