Hello!
I am using IS 7.04 with a MSI/Standard project. When testing, I find that three different versions of my application will install and uninstall OK.
However, if I install V1 and do a major upgrade to V2, the uninstall of V2 does not work properly. The status bar seems to go over all too quickly, and the add/remove programs entry is removed, but the files and shortcuts are not!
Can anyone help, please?
Major Upgrade No Uninstall
PaulDeveloper
, Feb 18 2003 12:17
Posted 18 February 2003 - 14:44
I also get this, when upgrading from V2 to V3:
"Another version of this product is already installed. Installation of this version cannot continue. To configure/remove this product, use add/remove programs on the control panel...."
Using add/remove programs, then installing V3 works, but is a bit unprofessional.
Now, I'm more confused!
