I have a checkbox in ReadyToInstall dialog box, for some of conditions I have to disable the checkbox, this is the scenario: In ReadyToInstall dialog my setup has to read the property value in the windows registry (ie. if HLKM\SOFTWARE\mysoftware\mycheckboxvalue is 0 then the checkbox is disabled and unchecked otherwise it will be enabled) .. how to deal with this.. I need advise .. BTW .. I am using IS 10.5, thanks a lot in advance
Teddy
disable/enable checkbox
Teddy
, Jan 25 2005 02:25
Posted 25 January 2005 - 15:57
In the bahaviour section of the dialogs view you can specify control condition. Use this to disable the control based on a property value.
You can read the value from registry using the System Search view (if the registry entry already exists when your setup starts).
