2x in add/remove list
tomsills
, Dec 23 2004 02:11
Posted 23 December 2004 - 02:11
I have InstalShield Express 5 sp2 on XP.
I change only the product guid (not the upgrade guid), and my newer install works in the sense that the shortcut takes me to the new version, but the old and new versions both show up in the add/remove programs list.
Tom
Tom
Posted 23 December 2004 - 10:20
This typically means that the uninstall of the old version didn't succeed. An MSI Log of the update should give you details.
Posted 23 December 2004 - 15:57
Thanks. I see 'log function' and 'log method' in the help index, but I do not understand where to begin with these. Is there another place in help that explains this? It seems to start in space for me, and I cannot find the context anywhere in help, FAQs, etc. Maybe there is a book available ?
Tom
Tom
Posted 23 December 2004 - 19:38
Now I have it requiring the user to uninstall the previous version manually in Windows Add/remove. That is not the most elegant, but is much better than having the app show up twice in the add/remove list. And it indicates that the installshield does recognize a prior version of the same product.
Posted 27 December 2004 - 10:59
Posted 28 December 2004 - 00:00
I am using InstallShield Express 5.0 sp2.
None of the things in that reference seem to work for me. I opened a command window at the folder where my singleimage setup.exe is. I tried various ways of passing the startlogging commands, but no joy.
Tom
Tom
Posted 31 December 2004 - 10:16
setup.exe /v"/L*v C:\log.txt"
or use the registry method.
Posted 04 January 2005 - 01:29
That got it. Thank you !!!
If you're curious:
I had a copy on CD of the previous ise, supposedly with an accurate Upgrade Code. But no !
Tom
If you're curious:
Tom
