I set ALLUSERS=2 initially (raw in Property table). Later even if I choose "for current user" installation mode (in GUI) and set ALLUSER to "" (with SetProperty control event), shortcuts will be installed in AllUsers section. What's the problem here?
Trouble with ALLUSERS property
igodunov
, Mar 06 2006 12:25
Posted 06 March 2006 - 17:13
It seems Installer set ALLUSERS to "1" (I see this value in property section after INSTALL action is completed /in log file/). Is it possible, that during InstallUISequence I can't override some properties that were initially set?
Posted 06 March 2006 - 17:14
A verbose log file should tell you (ideally on MSI 3.x because in this version it also logs all property changes).
In yor control event try {} instead of ""
