1)I have a requirement where i am using a Small update to update some files between versions of my product, i am doing this by changing the package code each time the setup is created. Now what i want to do is , i want to delete some files from the target system when i update my software this is because the exe generates some runtime data files which are not compatiable between releases and i dont want to suggest the customer to delete it manually whenever they upgrade the software , can you please let me know how i can accomplish using the small update feature in installsheild.
2)What is criteria for the files to be upgraded , whether a txt file which is changed between version will be recopied during the upgrade or only versioned files will be upgraded.?
Your help is much appreciated.
Regards,
Balaji
Edited by balaji4u, 28 September 2011 - 10:11.
